eflyguy
2500 Posts Club!
Back "when I was a boy," cars usually took 5 quarts of oil...
They still do.. unless they have turbos.
Without a "Used Oil Analysis," all intervals are somewhat arbitrary. Depending on the oil used, the fuel used, driving style, environmental conditions, etc., your oil change interval may be shorter or longer than any "standard" recommendation. Rather than do an oil analysis, people tend to use top grade oils and follow the manufactuer's recommendation for oil change intervals (OCI).Went in today for my 2nd oil change at the stealership today
They told me the interval they use is every 7.5k since "I am full synthetic at that they wanted to use the most out of it".
My first oil change was @ 7k, I came in at 11k, they told me to come back ~14k.
I am thinking about calling them to reschedule when I am at 12-13k right? Just explain to them that the manual states the interval at every 6k... :/
Just read through the manual for my '19 GT1 (just picked it up today), and for the Theta 3.3, they removed everything except 5w30 and 10w30...So take your pick based on your temperature range of driving, desired MPG, style of driving (high reving RPM in the hottest conditions vs casual city driving in the cold)
If you want to more accurately determine your oil actual/needed change interval, companies like Tribologix and Blackstone offer these services. If not, simply use a quality oil and follow the manufactuer's recommendations. That being said, a 7.5k mile OCI is a reasonable number provided you accumulate these miles in less than one year and your car is being used as designed.
Does anyone know the capacity of oil removed? I know when you drain or pump out the oil you do not get the full 7.29L out.
Thanks in advance,
Hmmm wonder why 0w30 cannot be used for 3.3t?
While 5w30 are good the general consensus is 0Wx contain greater amounts of superior base oil such as PAO
Kixx makes excellent oils.The amount of PAO/ester oil depends entirely on the mix. You can get 100% PAO/ester based 5W30 oils - Penrite for instance have this: 10 TENTHS RACING 5W-30 (100% PAO & ESTER) | Penrite Oil
any brand to recommend for 5W-30 SN PLUS(prevents LSPI) in Australia? cheers
