I had been waiting for the
g70 but with the ridiculous pricing on that I'm now moving back to my original thought of the stinger gt (I prefer the more practical hatch anyway)
A couple of things that I'm a bit concerned about
I'm hearing stories of rattles and creaks etc after a while, does this tend to be only in the early models ? have they now got it under control
I test drove a 2017 build 2018 Stinger in February 2019 with 28,000 km on the clock, this was enough to buy the car it was silent and without any noise issues and was a hard driven dealer demo. I had this car for 2 days and can assure you I was not at all kind to it. My Aug 2018 build MY2019 car is perfect no squeaks, rattles or any strange noises. My opinion of the squeaks and rattles are limited to small quality control issues on the production line and not something systemic to the vehicle.
When I last looked at this some 12 months ago, the fitting of the tow bar was horrendous, they cut out a huge section of the bottom apron, do we know if they've remedy this problem
The factory tow bar looked horrendous to me when I looked at it in the dealers. so I've looked at this bar in Australia
Stinger, for light towing loads it is superior, yes they still have to cut a hole in the rear diffuser, but the end result is much cleaner. The fact the entire tongue and ball assembly can be removed, it does not upset the aesthetic of the vehicle when towing is not required and it's cheaper than Kia's tow bar if you don't get a tow bar thrown in.
I note that the recommended fuel is actually only regular 91 unleaded, has anyone noticed any advantage in running higher octane, do we know if there has been any dyno testing done comparing high and low octane
There are several issues with all comments here, but I will state some Engineering facts about the engine design and about fuels.
1: Dyno tuning when all that has changed is the fuel RON/Octane, will not show any performance improvement, it just won't.
2: The car is tuned for 91 RON fuel in Australia, using anything but 91 fuel without the engine being tuned specifically for a higher RON/Octane fuel is just wasting money on expensive fuel.
3: Sorry all but, anyone who puts higher RON/Octane fuel into a car that is not specifically tuned for that higher RON/Octane fuel and states "they get more power, cleaner running, better acceleration, better economy, etc", these points of view are purely subjective and not backed by any scientific fact without appropriate tuning of the engine.
3: The 3.3L T-GDI (Turbo Gasoline Direct Injection) Lambda II engine with a compression ratio of 10:1 (this is high for a turbo charged engine) employs direct cylinder injection. This is a very important distinction from MPI engines (Multi Point Injection) because it allows a high compression turbo charged engine to use low RON/Octane fuel.
This is achieved by introducing fuel into the cylinder from the injection system at the point of ignition (generally in 3 to 5 micro bursts measured in nano seconds). The fuel is NOT mixed with air in the intake port or manifold before entering the cylinder. Therefore the old principal of knock from low octane fuels does not apply to this engine technology.
For the record the fuel rail pressure for the direct injection system is somewhere around 3000 PSI to overcome the pressure in the cylinder when the fuel is introduced for ignition. Knock cannot occur with this engine design as there is no fuel in the cylinder to pre-ignite and cause knock during the compression stroke.
4: To balance the argument, yes the engine can be tuned for higher RON/Octane fuels and get significant power increases, but only if it is tuned for it, and considerations to intake and exhaust systems would be required. Although KIA have left a lot of meat on the bone with this engine a simple bolt on RB4 or other aftermarket piggy back ECU can get some serious power gains with no other hardware required and using a map for a higher RON/Octane fuel.
From an Engineering perspective the engine is a real gem, and given KIA have backed it with 7 years warranty I would suggest with regular servicing and in standard trim the engine is all but bulletproof.
I hope this helps. Sorry for the rant.
