Did the spark plugs change today with Denso IKH27. Fixed the misfire issue. Car is running fine and no coil pack damage. I will push the car to its limits to make sure the plugs are doing there job.
What plugs did you have before?
Gap?
Curious as to why 2 steps colder? Especially considering that you will be running WMI, which will suppress detonation. And should not require going so cold on the plugs... I would have though you would want to run oem plugs with WMI.
