So I debadged my Stinger yesterday and noticed that once I removed the little stinger emblem there was an indentation where the stinger badge was. I'm not a big fan of it so I'm looking for a stock singer emblem to put back on it. Any ideas on where to find the stock emblem?
Agree.....it looks like the paint hadn’t hardened enough before the production line applied the OEM Kia badging.Mine had the same indentation, front too. Looked like they put the emblems on when the paint wasn’t yet cured. . I had the back piece repainted
Cutting that tape so that it’s not visible behind here I think isn’t worth the effort, the tape itself isn’t cheap, the badge not much more so. If you trust yourself to scribe the tape and cut it to shape by all means, go for it, but it's obviously not going to be as simple as cutting it to length and plastering it to the back of the car. The tape comes double sided, one side sticky, and one side to peel off.
You'll need to apply the sticky side to the back of the stinger badge, then cut the sticky side with an xacto knife, the blade will stick to the tape as you cut, be careful not to cut the plastic badge, but cut very close so that the tape isn't visible once applied to the car, as you can see from the picture the OEM badge adhesive is recessed by about 1mm around the edge, but after cutting it'll be right up to the edge.
Personally, I don't think it'll turn out well and you'll end up ordering a new badge anyway
2018 Kia Stinger Parts - Nameplate - 86312J5100
https://www.amazon.com/3M-Scotch-59...ywords=3m+vhb&qid=1559056070&s=gateway&sr=8-3
Sounds messyHoly crap, I would probably leave because of the spiders, but would definitely leave because of the cost of badges.
Problem is that one side of that tape is always sticky, you have to stick it to something as soon as it comes off the roll, so really the only option is to stick it to the badge first, then cut it out around the badge.
The large badge is in 2 pieces , its not broken , try spray adhesive , just spray the bottom from directly above so you dont get over spray on the sides of the letters ............good luck
I'm thinking about just getting mine repainted as well... about how much did it cost for you to get yours done?Mine had the same indentation, front too. Looked like they put the emblems on when the paint wasn’t yet cured. . I had the back piece repainted
