Broxk
- May 26, 2019
What happened to the one you took off?So I debadged my Stinger yesterday and noticed that once I removed the little stinger emblem there was an indentation where the stinger badge was. I'm not a big fan of it so I'm looking for a stock singer emblem to put back on it. Any ideas on where to find the stock emblem?
Can you take a pic of the indentation?
I still have it.What happened to the one you took off?
The one I took of is pretty much new. I've had it for 5 days now lol. I was thinking of just putting the double sided 3M tape on it and just putting the stock one back on but I wouldn't know if that's work or not.I trust a lot of us have the stock ones we removed. Or are you looking for new ones?
I still have it.
Taking off the badge usually ruins the adhesive pad, it won't just go back on, it's pretty much garbage.What happened to the one you took off?
Personally, I would just buy a new badge with the tape pre-cut and ready to seal off those holesJust remove the old tape, apply new tape, and put it back on.
No @Kamauxx was correct, I misread and thought it was the Kia badge both front and rear have positioning pins. Not the small stinger badge.What holes? Got pictures?
Mine had the same indentation, front too. Looked like they put the emblems on when the paint wasn’t yet cured. . I had the back piece repainted
@Broxk Can you take a picture of this ridge? Is it possible that it’s just a bit of buildup from the original glue? I used Goo Gone on mine to clean it up, there was a little ridge on mine too, but it was only the adhesive around the edges. The metal itself should be perfectly smoth.
