washguy
Angel my home depot has em I like real hardware stores though " hose dill"" tubing insert" if I use a compression fitting and tubing I for sure will use one of these...guarantee no leak no crushed tubing.
you are dealing with push lok fittings...and compression the insert goes into tubing the use the compression fitting normally....you must tighten down compression fitting enough so it cant be pulled out ! 1986 to just recent...carwashes....if there was a crazy type fitting ive used them....lol Wash
