PRESSERtech LLC
- Jun 28, 2018
Hi
Absolutely this is necessary when tuning on the dyno. We tune these cars with AFR of course, as well as data logging in all loads. This client mailed his ecu to our shop to tune. We use data from our local clients and use the cars adaptive logs to build the perfect tune. We set safety limits so afr cannot get too lean. When doing builds like you have done your talking a whole new level stage of tuning where data changes dramatically. We tune in these sceneraios too and always go to dyno for logging when making that kind of power. We are in the middle of a stage 3 build on a S65 amg and i will be able to set a base tune and tweak it after we have dyno logging.
Ive had many many dyno pulls with the three different engines in the z06,and in all those many pulls theres a lamda sensor in the tail pipe....without the afr's telling you what your particular engine is doing air/fuel wise...all you have especially with a forced induction engine is a ticking time bomb....Why no sensor in the tail pipe?.....lemme tell ya from running a blown gas engine making over 1000hp ...we looked at plugs after every run...doesn't take much to fubar a piston....a lil burning/chipping away at the top land is all it takes..... on my twin turbo 482 lake boat we put out 32 pounds of boost,but I had a giant intercooler pumping cold lakewater into it,also running VP race gas ....never hurt that motor.....on the blown dragboat motor we expected to burn pistons....that's why I had three motors....lol....if it were me I would surely wanna know my air fuel ratio in my car no matter what tune I have
Wash
