Shrikecorp
Seattle, WA, USA
I've been sort of compiling and validating some combinations. Criteria: avoiding poke, trying to find ways to improve on the stock look without compromising performance too much, etc. Seems like an okay start, might be cool if we could add to it (original in Excel has formulas and all that bit.) Thoughts?
Corrected/updated:
Link to editable Google Sheet. Add your own, etc. Play nice. Wheel Tire Options
  • Added columns for AWD/RWD and lowered or not.
Seriously nifty comprehensive calculator linked by @YOWStinger : Rim & Tire Size Calculator. Custom Offsets
For tyre sizes and trying to keep to stock-ish rolling diameters (to avoid Speedo inaccuracy, or to avoid issues with AWD and mismatched sizes), there are a number of tyre size calculators online that can help. The miata.net site has one that has been my go-to for years - it's basic but it works (There are others out there that graphically show the differences, etc).
Tire size calculator
Great post, thanks for sharing this!
nks f
Indeed, that's what the Excel formulas are based on. I do find significant discrepancies between calculated values and actual diameters at times. Michelin appears to be more consistent than others (I'm looking at you, Pirelli).
If I may suggest, staggered 20 option B is
Front 20x8.5+30 245/35r20
Rear 20x10+40 285/30r20
This is the suggested TSW wheel size, I'm still working on validating +40 in the front which may not work depending on the shape of the spoke.+40 was used on the Federation Stinger on the front with TSW Sprints.
Excellent input. It'd be great to see living documents for quantitative information (perhaps fuel mixing, etc.., as well), updated by site members. Searching is tricky with terms repeated thousands of times. I'll integrate this data when I'm back to a PC.
20a wouldn't work. The rear tire would be way too small compared to the front. Since that looks like the specs from my car you probably meant to put 285/30 vice 285/25.
A 285/25/20 mixed with 245/35/20 would look like this:
I have a square set up - 19x9.5+25 and 255/35/19 tires. AWD on Eibach springs. Tight fit in the front, but perfect, not issues.
Thanks! I see my formula for calc diameter for 20A was borked, now corrected in Excel file. And it now aligns with the results you got from the TireSize calculator. :D The mix I was going for was 245/30 20 and 285/25 20, trying to stay very close to stock diameter, which gets us this...just .2"/0.8% difference, pretty close to the stock 26 and 26.1:
What's yours exactly, offsets and all?
Added in :)
FYI, This set-up results in 1/2 inch of poke front and an inch in the rear..
Added in :)
Another option for you which is my current 20” staggered setup
Front 20x9+35mm 235x35
Here we go. Posting this here, and I'll add the original post. Link to Google Sheet, open to edit for all who have the link. Add yours if you like, etc. Play nice. Wheel Tire Options
Added mine.
19x8.5 +32 // 255/35/19
19x10 +47 // 295/30/19
They are 0.05" apart in circumference
Also, I might suggest using this as the calculator going forward, which allows you to enter all of the specs including offset, tire size, and calculate fender and wheel clearance, etc. I should measure up what the stock fender clearance is.
E.g. Rim & Tire Size Calculator. Custom Offsets
That's excellent, really nice find :thumbup:...if we get the fender and suspension clearances, I can probably extrapolate the formulas from the results and incorporate into the sheet as well. That'd be great.
