Wasn't today but hadn't taken pictures yet. Injen Intakes
View attachment 23262 View attachment 23263
I see you're having the same folding hose issue, albeit less pronounced. If it gets worse, a bit of red silicone hose (shortest they sell is a foot) from Amazon did the trick for me. Not so stiff.Wasn't today but hadn't taken pictures yet. Injen Intakes
Could you indicate this "folding hose issue"? I am not seeing it. (trying to increase my education)I see you're having the same folding hose issue, albeit less pronounced. If it gets worse, a bit of red silicone hose (shortest they sell is a foot) from Amazon did the trick for me. Not so stiff.
LOL! They are water repellent "pre-filters" got them on Amazon: https://www.amazon.com/gp/product/B013EKGGZ0/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1Looks Great! My opinion is the best looking intake I just wish they had heat shields.
Are those filter condoms? Were did you get those.
When installed at Eurowise in Charlotte they showed me the kink which was worse before cutting the hose shorter. They said it is not kinked on the inside and will not affect performance at all. I may change it now that you've pointed it out it's going to annoy me too.See below circled in Red.
Are there any threads that compare the different intakes available and the pro's con's of each. My first mod's I plan are this, plugs and JB4
Yes there are.
Its all subjective.
This is my winner after all the research I did.
I have the Agency power intakes because they made out of plastic and have heat shields. They also use dry filters. Minimal heat soak.
But do you have the hood sealing issues others have reported? They were my choice until people had misaligned hoods.
Now that looks sweet.Yes there are.
Its all subjective.
No u didn't, you altered the hue lolWrapped O'Hara ... virtually. She used to be Hichroma!View attachment 23298
Chromatically would be the more correct word.Key word: "virtually"
How much for the wrap lolWrapped O'Hara ... virtually. She used to be Hichroma!View attachment 23298
