The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Went to the spot for another test run this am and state troopers were waiting for me, followed me to work, lol I guess the word is out.
Followed me to and thru the car wash no joke.
Think I'm done testing.![]()
Also be sure your oil temp is 200 or better or LC may cut throttle and bog for almost 1 second.AWD, when I practice on the street it just feels weak coming out of the hole.
My dogs name is broly...
If you are too cool then try to use Auto Hold instead. When I had a piggyback I did 4 tests back to back and LC was only .04 faster than AH.
However if you use AH you can leave at the second yellow instead of the 3rd as it adds .4 to your reaction time. (don't jump the 2nd yellow but leave earlier) That doesn't impact your ET but more fun to hit a good light and get over the line first.
If using LC how long do you stay on it before you go?
The easiest way is to stage and hit the gas on the first yellow and let off the brake on the last yellow. I like to rev a little longer but if you start when you are BOTH staged that is a little too long and run the risk of LC shutting off. I had an abnormally long lag between stage and the first light and I did time out LC once. Since it was the first run of the day I suspect it cost me a record time.If using LC how long do you stay on it before you go?
Or you can give it a good long one one one thousand count after you are both staged and hit the gas.
Still going strong even at 12. Raw diet is the way to go.Awesome dog and awesome name!! Looks like he is about to turn super saiyan on that picture lol.
Or you can give it a good long one one thousand count after you are both staged and hit the gas.
You never really build boost just rpm and get out of vacume. The first to 3rd yellow light is only 1 second. That works pretty well but would be the minimum. 2 seconds seems better. On dragy i just count to 3 but not that slow.There is a delay between hitting the gas and getting the “LC active” message. How long does it take boost to build from “LC active”?
I hit consistent 12.3s but couldn’t get a 60’ below 2.0 using LC or AH.
we dont really build boost in LC until you let off the pedal.There is a delay between hitting the gas and getting the “LC active” message. How long does it take boost to build from “LC active”?
You AWD or RWD? What kind of tires? You recording on the street or track?
What are your mods?
You hit 12.3 on dragy or track?
You need better tires. Our rwds spin like crazy. Even with semi slicks i had spin.those p4s are good for the street not ideal for our rwd at the track. Awds wont have issues.RWD, 285 Pilot 4S, Track
