No need to argue on the past.
A mod or Someone should add this criteria on top of the 1/4 list. From Today forward lets follow a basic set of guidelines to accept 1/4 times. Simple as that lets not dwell on the past, lets move forward together.
From now own lets try to have some basic criteria to post the results on the list. Everyone lets try to follow this guideline so we have a standard process. This will help all of us on the validity of the results. This will ensure to keep the list as validated as possible and fair for everyone. If you can't meet the below criteria then you should not be on the list. Lets keep the list separated as it now. Top 10 track results on top and top 10 dragy results on bottom.
For Track Results:
1. Provide picture of track Slip. Try to provide a picture of the track slip by your car number if possible, this will ensure the track slip belongs to your car.
2. Video of track run. Its 2019 and everyone owns a smart phone. Have someone record you when you make your runs. If you break a record then this is the ultimate proof that no one can deny. This is what will make your run 100 percent validated. Of course make sure you record the time at the end.
3. List all performance
mods, including tires, WMI, Nitrous, weight reduction, etc......
For Dragy Results:
1.Post the dragy slip/result. Your name should match your user name or real name to make sure you used it on your car.
2. If possible have someone record you, although not required but helpful.
3. Be honest about the conditions you ran in, meaning temperatures. Winter time vs summer time. Dragy should be used more as a performance reference, rather than the ultimate 1/4 results.
4. List all of your performance
mods.
