TwiceStung
Here is a direct quote from DuPont on their water-based paint vs solvent. This was several years ago. It refers to after-market body shops but there is every reason to believe it applies also to OEMs.
Going from 4 to 6 coats to 2 coats of paint will make a thickness and ultimately a durability difference..........
“Most other waterborne products went in the direction of trying to create a waterborne paint that was like solvent-based paint,” Christman explained. “Solvent is the old technology, and painters tend to dislike change. So many paint companies, when they created their waterborne paint, said ‘we’re going to make them like solvent.’ We went a different direction.
“It’s a higher solids product, so it’s got more of the stuff that gets left behind when the water evaporates off. It’s a one-and-a-half coat, wet-on-wet process. Rather than having to lay down a coat of paint, let it flash, then lay down another one, let it flash—and, depending on what you’re working with, lay down four, five, six coats—with Cromax Pro, you cover in one and a half coats. And anything that doesn’t cover in one and a half coats covers in two coats. So you go in, put on the first coat, go right back and put on your mist coat, your ‘effect’ coat, which is half a coat. Then you’re done. You can put the gun away; leave the booth. It will dry, and then you can clear coat it.”
