Coast GT
1000 Posts Club!
Happens all the time for me. I’m booked in for the 10,000km service on Friday I’ll ask them about itIn 9 months I've had that happen maybe 2 or 3 times.
It'll be interesting to see if they are aware of this issue (ref. post #1147), and whether there's been a software update to rectify? Let us know what you find. Thanks.Happens all the time for me. I’m booked in for the 10,000km service on Friday I’ll ask them about it
Sounds silly but discovered that once you have the car in manual you can put it back to auto (D mode) if you push the gear shift down.
This is completely normal happened always in my other cars as well.I put on sunglasses for the first time in Stinger and was shocked. HUD disappears.
maybe it's because of polarized lens?
I was thinking sunglasses would make it dimmer but not completely unreadable.
Turn Signal Not 'popping back' on Left Turns...
About 1/2 the time, my turn indicator stalk is not popping back after left-hand turns. Started out occasionally a month or two ago, now it's about half the time. Depends on speed and sharpness of turn, e.g., normal-speed turns will not return; sharper/faster turns will pop back. Will have it checked-out next time I'm at the dealership. Anyone else with the problem?
I been with KIA for a while, new to me.I learned that the radio preset change toggle on the steering wheel can also be used to tune down or up if you hold it in either position. Prob old news for folks that drive other Kias, but new functionality for me...
yes it does on my other cars as wellIf you listen carefully as you rotate the temp knob by one click at a time, you can hear the little motor in the AC unit make adjustments with each turn. It helps to hear if you're in Park with the radio off. I figured the motor was moving the door to the heater core. Is this common in a lot of modern cars?
I never noticed that, good find.I've been driving my GT Limited for 8 months now and today I just realized that when you switch the drive mode to sport, the HUD speed is italicized. A nice little touch.
Yeah mine does something similar. A long sweeping left hander won’t trigger it to pop back but a 90° turn will. It hasn’t annoyed me enough to do anything about it yet but I’d be interested to hear what your dealer says about it.
I am having the same issue om my '18 GGT2. Going to stop at dealer tomorrow.Turn Signal Not 'popping back' on Left Turns...
Has anyone noticed a mechanical sound when engaging the parking brake?
Wow! Really?Discovered that when going downhill engine revs goes down and mpg goes up its canned coasting feature to save gas.
Fed ruination, another sad story of blighted hopes and design. Look at that puss, only a bumper is all you see.Wow! Really?Back in college I had a '74 Saab Sonnet III. Very interesting car in many ways and one of the features it had was a throwout bearing on the 4 speed manual transmission. When you let off the accelerator, it would go out of gear and then when you pushed on the pedal again it went back into gear. I averaged 35-40 mpg out of that 1.7L V4 engine. Could easily from 55 mph to 70 going down a moderate hill. Made it great for drafting during the oil crisis years too. Here is a pic of a Sonett just like I had (even the same green)!
Early '70's safety regs.Fed ruination, another sad story of blighted hopes and design. Look at that puss, only a bumper is all you see.
