Thanks for info. He did try the FUD bit update and it helped a lot, but didn’t resolve it completely.
FYI- It’s definitely worse using part throttle, but boost still fluctuates over 15psi even at full throttle. Just feels like it can’t hold solid boost anymore and is constantly fighting with itself.
If this is just an EWG oscillation from high boost targets wouldn’t everyone using map2+ experience the same fluctuations?
This is only the second log I’ve seen with 1-2psi variations while accelerating so feel it may be a combination of mechanical and the JB4 PID control. Unfortunately using stock boost(map0) it’s not noticeable so unsure how to test if it’s simply the JB4 fighting with the EWG control. However if a few users have the same oscillations then hopefully its just a JB4 setting that can be adjusted.
Is there another fix available that totally eliminates the fluctuations? Or do you have any ETA on the direct EWG control?
Any other suggestions and updates will be greatly appreciated.
