Ultimate Performance HFC Down Pipes are installed on the car.You never know, will these work with ultimate performance hfc down pipes when available?
Ohhhh man, the track is going to get a treat!
I want to see that too and I fear that the Stinger is going to have 'Supra syndrome' because of traction issues. I wouldn't be surprised if we're still stuck in the high 11s with mid 120s traps.I want to see 11.4x@123/4 is my guesstimate. As soon as the launch control gets figured out our ETs are going to be where they should IMO
Legitimate concern, however with a 18” wheel in the back and 1” overall shorter with a sticky will solve that on the RWD cars. I’m really excited to see how the awd cars do. We are still really really early in all of it.I want to see that too and I fear that the Stinger is going to have 'Supra syndrome' because of traction issues. I wouldn't be surprised if we're still stuck in the high 11s with mid 120s traps.
I wonder if we could do 17s in the rear if we swap base model brakes onLegitimate concern, however with a 18” wheel in the back and 1” overall shorter with a sticky will solve that on the RWD cars. I’m really excited to see how the awd cars do. We are still really really early in all of it.
I’m sure it could be done, but I doubt it would show enough return over the 1” overall shorter with a nice DR.I wonder if we could do 17s in the rear if we swap base model brakes on
He will probably need an ecu flash ...The good news is the turbos make the boost. The bad news, we're going to need more tuning work to get matching 1/4 mile times. Main changes needed are a higher flash boost target with less taper to redline, higher calculated torque reading for the trans, and maybe 2 degrees less timing across the board. Being able to launch mode at a higher RPM would be great too if the converter allows it. Sadly low 11s will have to wait until a good back end flash map is available.
Thanks for your time Terry. Well get an ECU and already have someone to flash it for us. Well be back at the track in no time
I agree I don’t think a JB4 is the right Tunning solution for that sep up of bigger turbos ....Yup. ECU tune is going to he needed for these turbos to be worth while.
Needs certain changes done that are best done via flash for sure, and will need the JB4 for boost control, WMI control, logging, safety systems, fine tuning, and a host of other features. Larger turbos are the perfect application for a back end flash map.
Can you guys post some times. I'm sure you ran some draggy times and we were told a track was rented for today.
IMO I think it is with a back end flash. Unless you wanna be on kill mode all the time. To each its own, but i like to control boost and fuel as needed. So with Terry’s input well make a Back end flash and still have flexibility. I can raise and lower boost, tweek AFRs, trigger Meth, fill with e85, all on the fly. Even valet modeI agree I don’t think a JB4 is the right Tunning solution for that sep up of bigger turbos ....
