Does the Racechip require the HKS plugs
Seriously man, do what @KLR STINGER says.
There was just a post last week from someone running RaceChip with stock gapped plugs. He pulled his plugs to upgrade to a different brand and noted several of them were cracked.
RaceChip is providing bad guidance.
Sounds like they are... I specifically asked about regapping and the answer I got was no need and not to worry about it. I’m going to anyway
I have a very important question about this product! does it currently have the ability to REMOVE the speed limiter of the stinger if not will it be coming in the future?
The speed limiter on the stinger GT is set at around 167 mph I believe ,, which is I guess approx. 267 km ,, for myself I have not hit the limiter as of yet ,, but that is moving along at a good rate of speed speed indeed . I thought at first that was falsely stated, as most cars here are set well under that ,, but FYI the car will already run at close to 270 ,I can in tell you that ,,LOL
I can tell you ALL the AWD drive models for the first few people like myself was FALSELY advertised and the speed is limited to 130MPH so I got the royal screwing. This was before KIA covered there ass with all the fine print. Please don't attack me for saying this I know some people on here think they are lawyers and Master technicians so please keep your comments to my response to yourself !!! thanks !!!
Only limited with the 18 inch wheels. My Awd goes faster with the 19s.
Tork ecu tune can raise the limit for you.
From what i have seen the recomended octane for 5 or sport is 91 octane and race or 7 is 93 octane .
TonkaBob ,, just added my JUN BL Mid pipes which removes the secondary CAT S, yesterday ,, just tried a launch with it and my engine went into limp mode for a brief time ,, has this ever happed one else before ,it was like the injectors shut down a brief time and thoughts on this anyone ???
If the fuel cut was right after launch your oil/ trans was too cool. Be sure oil is 200 or more.
Too little octane will often sputter first then may cut throttle.
Thanks perhaps the octane was low and perhaps the tranny cool , I just got back from run to another city so it should have been hot enough but trip was relaxed posted speed run , just added Boostane now ,so I bet the octane level was lower :)
