MekstingerGT
- Apr 12, 2018
Anybody knows if the Stinger comes with a low oil light? I know theres a low pressure light. I saw a pdf showing it is available but diesel only.
Wouldn't low pressure and low oil represent the same problem?
Bummer. The reason why I ask is I have a catch can and after a couple of weeks I'm already seeing a large amount of oil. The only think I have is the jb4. A low oil light would help just in case I forget to check, heck even my wifes 03 honda accord comes with a low oil light.
Not at all.
Severely low oil level would obviously cause low pressure, but low pressure could be due to other things (like a blockage or fault at the oil pump). Moderate low oil level by itself would not indicate low pressure, but could cause heat and wear issues.
Sorry, but you are misinformed. There is no oil level sensor or indicator on your wife's accord. There is a low oil *pressure* indicator, which we have already discussed (page 347 of the 2003 Accord sedan owners manual):
That said, the amount of residue in the catch can should be insignificant compared to the total amount of oil in the engine, and you would normally just be burning it off in any case, so the system is designed to allow for that volume to be "wasted" over the life of the oil.
