Aftermarket Wheels
What is Your favorite Wheel?
  • Total voters
    235
@MekstingerGT looks good...what are your offsets and did you stay with stock tire sizes?
Thanks for those that helped me with the right wheel size to get.
Went with Vertini 20" RF1.3's in Silver on a staggered setup 9/10.5 245/35/20(F) & 285/30/20(R) + Eibach Pro Lowering Springs + a lil sumpin...
Little!? That thing takes up the entire trunk! I bet people can here you before they can see you coming, lol!
The offsets for Vertinis should be +35 and +45 when using 9 and 10.5 wheels.
Posting a long post to hopefully minimize audio questions in the wheel thread.
brancky3 - amazing. The hatchback really reflects back into the car well while still banging nicely outside as well. On the hatchback in the upper middle, there is a black panel (light or rear defrost box?) I added a lil flat padding (lift and insert) as that was the only interior rattling of mention.
Externally close to no rattling. By comparison, my previous car "14 Ford Fusion had a similar setup but rattled like "HELL!" externally. I had Dynamat installed three different times! Very good question. But for those considering bumping this car handles things well acoustically.
I listen to a lot of old school hip hop and r&b with a lot of bass. I tuned this to hit nicely but not obnoxious destroy the car loud.
Last thing to mention, I can't say enough about the DSR1. It turns your factory deck into an aftermarket with adding voltage and cleaning up the signal and adding ton's of options for your phone or Apple Watch. Thing Audyssey for those into home audio.
All Fosgate Power Series or Line:
- 1500 Amp (burst rated 1800 watts rms) gain set to 5
- 400 Amp (burst rated 535 watts rms) gain set to 4.25
- 6.5's x4
- Power components / hi's x4 (had hi's installed in the rear to match the front / same location but in the rear)
- Power T1's 12" x2
Topped it off with:
- DSR1 signal processor
- 1/0-gauge wire
- 100 watt fuse & circuit breaker
- Custom box
- Beauty panel for the amps
- Optima Yellow Top Battery
- 6.5's x4
- Power T1's 12" x2
Topped it off with:
- 1/0-gauge wire
- Custom box
You should add to or start a thread in the Technology/Audio section on this for folks who want to ask more on it.
I hey guys I don’t see anybody runing the specs I want do you think it would fit. I have eibach springs.
20x9 +32 front
20x10.5 +45 back
Tried posting some picture of my ChromaRed with the Ace Alloy AFF005 but since I'm new to the forum it won't let me.
