So tonight I was out having some fun just driving around. Took a turn from a stop at WOT trying to kick the backend out and burn a bit of rubber. Stability and traction control disabled moments before manually. Start spinning tires a bit and the backend starts to lose traction. Wide open throttle here. Car completely cuts throttle and I lose power for at least a second with the pedal to the floor. The f*ck? Ok.
Using JB4 Map2, maybe something is going wrong. Check my logs. Something I don't know about is definitely happening. Logs look crazy. Let's set her to map0 and test again. Make sure I turn off traction and stability control again. Same exact thing. Is there something I don't know about going on here? Is this harmful to the car? Anyone have any clue wtf is going on?
Maybe I'm dumb, but I've never had a sports car I couldn't burn a little rubber in. Is this the same for everyone else? Has anyone tried drifting this car a bit?
Attached. Map0 log of 80%+ throttle 90 degree turn.
Only mods I have are densos gapped to .022 and a JB4 which I set to map0 for the test.
