WOT on a turn from 0. What does your car do.
I can easily get the back end to kick out and have to let off the throttle to regain control, but never tried full drifting or donuts. However I’ve seen multiple videos like this so it must be possible...
I just wish there was a way to power brake and do a small spin to warm up tires for track days. Anyone figured this out either? Seems like any brake pressure just cuts off the throttle so a quick standing tires spin is impossible. Anyone found a way around this? Or is this tied to the same “nannies”?
2018 or 2019
I haven't tried it yet myself, but this guy doesn't seem to have any issues doing donuts. I wonder what the deal is.
So tonight I was out having some fun just driving around. Took a turn from a stop at WOT trying to kick the backend out and burn a bit of rubber. Stability and traction control disabled moments before manually. Start spinning tires a bit and the backend starts to lose traction. Wide open throttle here. Car completely cuts throttle and I lose power for at least a second with the pedal to the floor. The f*ck? Ok.
This happens to me all the time more with left handed
Using JB4 Map2, maybe something is going wrong. Check my logs. Something I don't know about is definitely happening. Logs look crazy. Let's set her to map0 and test again. Make sure I turn off traction and stability control again. Same exact thing. Is there something I don't know about going on here? Is this harmful to the car? Anyone have any clue wtf is going on?
Maybe I'm dumb, but I've never had a sports car I couldn't burn a little rubber in. Is this the same for everyone else? Has anyone tried drifting this car a bit?
Attached. Map0 log of 80%+ throttle 90 degree turn.
Only mods I have are densos gapped to .022 and a JB4 which I set to map0 for the test.
This happens all the time to me doing hard left hand turns I just try to go gentle and if you wana peeel out accelerate before turning I just feel like if I keep trying to recreate it somethings gona break
If everything is warm I melt the inside tire...no lsd . Still keeping an out for a wrecked one that I can nab for ~600.00
