JustThatPenguin
- Feb 28, 2018
What viscosity grades is everyone using? 5w - 30?
It gets pretty hot here, so I am running 5w40.
READ YOUR MANUAL!!!!!!!!!
For farks sake.
For farks sake.
Sorry for pulling up the old thread. Kia recommends 5W30 and 10W30 depending on temperature. I think if temperature permits, 10W30 is superior choice.
Here's a good discussion:
5w30 vs 10w30
Page 8-9 gives you the chart. Pick what fits your climate and driving. I could run 15w40, but choose Euro Spec Mobile 1 5w40. Nothing magical here. View attachment 16819
I think mines a little different, will post a pic if it is.
I think it's better to have 1st number (cold engine start temp viscosity) higher. So 5W40 is not better choice over 15W40 actually worst. (I think so by going over the discussion in bobistheoilguy forum).
Yeah, I am an avid fan of Bobistheoilguy too. It came down to availability of the oil and the fact that Kia recommends the 5w weight for better fuel economy. As I change my oil well before it is degraded, I believe I am fine. However, if it becomes readily available here, I will run 20w50, especially during the summer months.
Again, these are all permissible and will keep your PT warranty intact.
I use 5w40 based on the recommendation of my mechanic.
If I am in California, I wouldn't. Oil evaporation is high on lower 5wXX oil. On GDI engines that's an issue. The heaviest weight oil that weather permits should be used out of recommended oils.
It is good have something that you can hold onto, and I applaud your efforts here. Yet, I have to let you know this assertion regarding 5x40 synthetic oil has as much chance of catching traction as our summer tires do at 10 degrees f and six inches of snow.
After many years and many vehicles, I've arrived at a precision honed oil strategy:
1) Buy a name brand oil that meets the manufacturer's specifications - preferably ahead of time when it's on sale. I have no allegiance, and don't care if it's Mobil, Castrol, Pennzoil, etc.
2) Buy a good quality oil filter, not a generic - or the car manufacturer's house brand, which I know is good enough for them to trust for their warranty.
3) Change the oil at the manufacturer's recommended oil intervals.
So far, it's been infallible - never had a good engine turn into an oil burner, make noise, or fail. Too much other stuff going on to worry about chasing NOACK values.![]()
