TorkMe
 - Apr 4, 2018
So, the debate of which is better is getting heated with new records being broken everyday (well, with the exception of one) we need to talk about tuning.
Now, setting aside the ease of install, shipping the ECU, ect. I simply want to talk about tuning the ECU and how its different from a piggy back. I want to field any questions that people may have about tuning the ECU, and if I can, I will try to answer those questions about piggy backs and the interference they play in the operation of the ECU.
At no time will I reference one particular ECU tune, piggy back or other, because... I am not here to point fingers or make accusations. I will simply post maps from the ECU (values have been changed to protect my IP) hiding the HEX address and we will discuss. Sound good?
Lets start with these 3 maps:
1. This is the minimum torque that the ECU will allow during a shift... this map I didn't change much, but you can see its -200 Nm. With an ECU tune, you can modify this value. With a piggy back... not so much.
2. This one is peak air flow for brakes applied, vehicle stationary. This is KgH in air flow. A change to this map will allow more air flow into the engine, with the brake applied. How cool is that
3. This next one is my favorite map to date... I call this my burnout mode map
  This map determines how much throttle opening you are limited by via KPH.  There is another map attached to this one, that limits throttle opening during launch control to 25%, and increases (linear curve) to 20 KPH. Reduce this map to 0 KPH, and... you have 100% throttle and 100% load from a dead stop.  Again, this is something that a piggy back tuner cannot achieve.
Now, the crazy thing about these maps... I have not used them in any car or any tune yet. I have been playing with one of them in my personal car for a while now, but the other 2 are brand new maps that I just identified tonight.
Some may ask, "identified the map"? Yes, I have to find the maps inside the ECU because there are no current map indexes or engineering files on the market for the Stinger (yet). So I am using a decompiler to help me find maps, and another map index from a friend over at (enter major automotive manufacture) to help me line up the offsets and get the transfer index working.
Offset is where I take known good maps, and align them in my map index. Its kind of cheating, and has to be confirmed in a personal car before loading into a tune. I use several different files to do this with, a big help has been the Audi and Merc files I have for lining up the different files via offset). A decompiler is software that takes the engineering binary and transfers it into a legible text. I still have to build the map, but I at least know my x, y and sometimes z axis data.
What does all this mean, well... with more data getting identified inside the ECU, we are going to start seeing the tuned cars get faster and faster as I spend more and more time inside this stupid ECU
  We have finished Stage 0 and Stage 1 tunes, we are now moving onto Stage 2.
Now, I am sure its going to get asked... when will we have pops and gurgles or raise the rev limit for LC or have two step for the LC. Pops and gurgles I have had for a while, just have not spent the time to play with is or adjust the fuel and ignition intervals for it... soon. The LC rev limit, we are struggling to find that and there is a very good possibility a new line of code will have to be written to go over that of the stall converter lock up, still looking into that. Two step... uhg, I am going to have to spend some time testing to make sure we don't fold over the turbine inside the torque converter. Its going to take a while, because we are going to have to go very, very slow and small steps to avoid blowing up the torque converter on my personal car
With that said... hit me with your questions and let me know what you think about the 3 maps I have shared with the community.
Thanks,
John with Tork Motorsports
Thanks,
