Happy to see flash tune customers finally posting some data! Log looks as expected, basically same as what we're running. Keep in mind boost and timing will vary based on IAT and baro. The colder it is the less boost the factory tuning runs and the more timing. As IAT heats up boost will go up and timing will go down. So you'd want IAT on there to evaluate how aggressive boost is set. If IAT is high it's a mild tune, if IAT is low it's a wild tune, for example. Also the Stinger uses an absolute boost sensor so the logging software needs to zero it out it's reading to get to absolute boost like we show. Seems to be -0.75psi at the start? The number of sample points and axis scaling will also effect how the log "looks".
JB4 log I recorded the other day except my boost in 1st gear is set to -6psi for stock tire RWD traction.
 12.4@118, nothing special. Hoping with traction to get down in the 12.1 range.
