GRStinger
If you don’t want to buy tools, you can always just use the jack and lug wrench that comes with the car. Do one wheel at a time. It’s super easy to do in the comfort of your own garage. I’ve been swapping the winter/summer tires on my Ford Edge this way for 5 years. It’s a bit slower process using the cars tire jack, but it’s free. The only tool I would recommend investing in is a torque wrench for applying the proper amount of torque on the lug nuts.
Yup, I used to do that for rotations etc., but it doesn't cost that much to get proper tools, and it's not expensive. I already had some of the needed tools - floor-jack and stands; bought some others for the recent change. I got most of my stuff from Harbor Freight. They are not the best tools - not going to debate that; they're not commercial grade and there are better DIY tools out there like Craftsman, but they work fine for occasional jobs Anyway, here's what you need / what I paid for tools to do the job:
Floor jack - $100
Jack stands - $25
1/2" Electric/corded impact wrench - $50 (it works surprisingly well)
1/2" Impact-quality lug socket/adapter - $10 (they're 21mm on my 18's)
Torque wrench: $30
I also paid a couple $ for a little nylon pry tool to pop off the plastic hub covers, but if you put a little duct or painter's tape on a flat head screw-driver, that'll work fine.
So, you're about $225 all-in. (plus all this stuff obviously comes in handy for other projects) I've heard most shops will charge you $100+ just for the swap/mount. Plus you need to haul your wheels/tires there and back, make and sit through the appointment, etc. (There are places that will store/swap. Hard to find, and they charge $150-200/year.) So I figure the payback is about 1 year for the investment. It's more convenient - you can swap 'em whenever you want. Plus you get the satisfaction that the job was done right. If you're a semi-competent DIYer, it's easy. First time for me took only a 1/2 hour to do the actually swap (but probably another hour+ to unpack the new wheels/tires, retrieve and set up my tools, and clean up - you know how that goes.) Personally, well worth it.
