For Sale XXR 559 Black Chrome Wheels/Tires/TPMS/Hub Rings/Lugs
Yup!
I'm surprised you haven't sold them yet. I really want some vossens but these look real good!
Shipping is the killer!
No longer available
Selling a set of XXR 559 wheels in Black Chrome. Purchased brand new on October 11, 2019...going back to stock.
Specs:
4 X 19x8.5 rims, 40mm offset (need 5mm spacer on front...included)
2 X Continental DWS06 Tires 225/40R19 (Front)
2 X Continental DWS06 Tires 255/35R19 (Rear)
OEM TPMS sensors, hub rings, lugs, 5mm spacers (x2) all included. Tires have ~6,000 miles and are all at 4/32 - 5/32 and rotated left to right regularly.
Prefer local pickup or meet halfway semi-locally (within ~100 miles or so).
Asking $850 PLUS shipping (actual shipping cost based on your zip code).
Reply or PM.
View attachment 34844 View attachment 34845
No longer available
I’m looking at these exact wheels and was planing to run 255 tires all the way around. I saw you said 5mm spacers needed. Was curious why the spacers were needed as the offset should be the same or further away slightly on the front vs stock rim? Looking for clarification before I buy mine is all. I looked up on will they fit website and it says it will poke 7.4mm outward more vs the stock wheel in the front. So I’m just curious why the 5mm was needed is all
Oops also where can I get the hub rings lol??
Hub rings you can find on ebay or amazon.
As for the offset. His setup was 40mm front and back. The higher the offset, the closer it brings the wheel to the brakes and struts. You need the 5mm spacer to clear the brake caliper OR you can find the same XXR 559s with a 20mm offset for the front and avoid spacers all together. If you are on facebook, join the Kia Stingers Owners Group and do a search on XXR. A couple guys are/were running them and state their specs.
The spacers are needed up front. OEM offset is 36.5mm and these are 40mm...brings them too close to the calipers (Brembo's).
Rears cleared with no issues.
There are a few other members with the same wheels and same setup who did the same.
Could be design of spokes. I’m running a 20x8.5 +40 wheel all around with no issues or spacers.
