I was pretty frustrated yesterday because I had seen similar wheels ran on our cars and they didn’t fit at first just glad I could get it figured out. In a perfect world I wouldn’t want to run spacers but the wheels came mounted and balanced so there was no returns on thenA good rule of thumb for threads (assuming male/female parts are of equal strength) is at least 1*diameter.
In this case, 9 turns * 1.5mm = 13.5mm, so you're a little over 1D, which should be
Hey 2020 gtrwd, I have a few questions if you don't mind.I was pretty frustrated yesterday because I had seen similar wheels ran on our cars and they didn’t fit at first just glad I could get it figured out. In a perfect world I wouldn’t want to run spacers but the wheels came mounted and balanced so there was no returns on then
Thanks for the reply. My new wheels arrived yesterday with the rings included and no spacer was required. So glad I did not have to purchase rings and did not require the spacers.Hey I originally purchased 5mm spacers to make sure I cleared the strut but my wheels when I bought them did not appear to be concave enough to clear the brakes so I ended up having to go with a 10mm spacer to push the wheel out far enough to be able to run them. The wheels were able to fit afterwards. I have extended lugs that are able to seat the wheel to the hub through the spacer because the spacer has larger openings than a standard stud hole. I do not know the brand of the 10mm because I bought them from a local shop here in my town. In the future I will probably just going to purchase another set of wheels so I do not have to run spacers. They make hubcentric rings that go from 67.1 to 76.1 diameter to be able to properly fit the wheel. I bought 67.1 to 73.1 so they should make the other sizes also
That’s awesome. I bought 20x9 et 35 thinking they would fit perfect because I have seen others run the same setup but it’s hard to see what a spoke on a wheel is going to do unless you see that exact wheel on you car.Thanks for the reply. My new wheels arrived yesterday with the rings included and no spacer was required. So glad I did not have to purchase rings and did not require the spacers.
