Widest Tires on AWD?
I'm running 255/35 and 285/30 nitto invos on 8.5 and 10" rim respectively. I tried 305s, but the rubbed with the offset I have(+40) . With a +45 the would have worked, but the 305s were also a little Wiggly on the 10" rim, and I didn't like the handling. The 255/285 combo is perfect with Eibach suspensión
Did you notice some performance drop in straight line acceleration?
Bigger meat will provide better traction given similar performing tires.
Sure but only in case the car lacks traction with stock tyres. The Stinger does not seem to have such problem.
It really depends on how you drive it. My buddy turned off the electronic nannies, put it in sport and manual and was able to burn tires down the road (RWD GT). With all the safety stuff on most people aren't going to have any issues. Some folks want to have the grip to manage the power and some will never drive their car anywhere close to it's limits. I've mentioned here about the time my Audi stopped in an intersection because I over cooked the brakes and wasn't using performance tires on the car. Whenever I have a high power car, I prefer to set it up so s not to have that happen again. Tires and brakes are typically the first things I change out. I have calmed down some since my younger years but I do take a romp every so often and while I'm more concerned about comfort, I still want the car to handle and stop as best it can. Not so much worried about the get going portion, but how it does while underway.
Depends on the Stinger. I lay rubber in 3rd! :rofl:
Do the electronic "nannies" remove power without the traction warning blinking? I have very rarely seen it blink when I was driving.
On more than one occasion, this AWD GT2 owner has turned a corner and upon hitting a slick spot (snow, ice) or a big enough bump while turning, the TC kicks on (light on the dash) and the momentum of the car abruptly stops. I believe the TC is kicking in thinking a wheel is spinning. But somehow the whole car slows down.
I'm going to be paying more attention to it this winter and will probably post more about it then. If this is how poorly tuned the TC is, not having an LSD is awful for any type of performance driving.
Hey Kazz, do you have 19s or 18” setup?
Shouldn’t however, if it’s managing the torque, it won’t come in either. My Volvo’s version of torque vectoring is to use the rear brakes to help the car rotate better. It wears the rear brakes down a lot faster than fronts. I’ve felt it several times and it was sort of weird when going quickly but the TC light never comes on.
Ah, those lovely Bridgestones. Once you get some better tires, your car will be a lot better. My first Optima Hybrid had some crappy Kumhos on it, the TC would kick in for just about everything! Seriously. Going into a corner too quickly, it killed the power and slowed the car to a crawl, hit a bump on the road, slowed you down. It was so annoying, I planned on trading the car. Changed over to Pirelli P7 AS+, I n the winter and it was like buying a new car! The performance of the car improved significantly and I could drive the hybrid like a normal car, the manual shifter got used a lot and cornering was more fun but then that let me know I would have to spend more on upgrading the suspension.
You might want to consider getting different tires for winter as those are not good for the winter. You might have seem my post on them in the tires and suspension section. Depending on how you drive, you might want to go with the Michelin PS AS 3+(or another of the top rated UHP AS tires) if you drive spiritedly and want to stick with AS tires all year long. If you want to stick with GT tires similar to the Bridgestones (but with better performance) you can get the Pirelli P7 AS+(get V speed rated ones). They are comfortable, quiet tires that do well in wet, dry and have great performance in snow for an AS tire. The TC issue you are experienceing is due to those tires not being grippy enough. Personally, I feel the GT’s shouldn’t use anything less than UHP AS tires but GT tires are fine if at least V rated, as they would be a bit trippier than H rated tires.
I'm going to be paying more attention to it this winter and will probably post more about it then. If this is how poorly tuned the TC is, not having an LSD (Limited Slip Differential) is awful for any type of performance driving.
Hyundai/Kia's idea of "Traction Control" is to kill pretty much all engine power, and not in a subtle way, either. Felt like a fuel cut in my Genesis, at least.
Anyone know the widest tires, front and back, that we can fit on the AWD?
Contacted tire rack and they said 235 is max width. Very few tires choices with that width in 18”.
Hoping the car can handle 245s.
Original Michelin Pilot sport 4+ only lasted a year and a half. Good tires but no life. I just bought Michelin Pilot Sport A/S 3+. I went one size bigger in circumference and width to both front and back on stock rims. It just snowed and the results were an amazing traction and ride quality difference. Lots of wheel well clearance and more wheel protection from the wider tire.
