This thread is really off the rails...not an expert but I will chime in to echo the sentiment that 50 weight is not junk oil, and 30 weight is not fancier nor does it have more additives/modifiers.
Modifiers are used to extend the spread between how an oil flows when cold and its base weight (how it flows at temp), a difficult problem ($$$) with tradeoffs.
A 10w50 would have MORE additives than a 10w30 because you're trying to make it act so much thinner than its base weight when cold.
The original question was not whether to run 50 weight, but whether you could get the best of both worlds by using a heavier base oil (Xw50 might be overkill, but same idea for 40 instead of 30) and dropping the cold number to 0. And the answer was that this wide a spread isn't free, so even though a 0w oil should flow a little better ice cold than a 5w, you have less of your XX base and it won't hold up the same.
So for any future readers of this thread, the best answer would seem to be: pick the base weight that'll protect you at temp (30 most places, 40 for hot locales or track duty), then a cold number low enough to flow reasonably at your winter temps, but no lower (5w for most, maybe 0w in Norway/Canaduh).
