D.J.
2500 Posts Club!
- Feb 24, 2018
- Location
- Toronto, Ontario, Canada
For me, in Canada, it's Kirkland Brand (Costco)- always best price.Whichever full synthetic is on sale at Amazon.
I used to buy that years ago when Costco first started carrying them and were even cheaper. Now they are around $18/5qt, which is still very good price, but occasionally some of the name brands go on sale on Amazon for about the same price, so I tend to stock up when that happens. I do wish Costco would carry more than just 5w30 and 0w20 though.For me, in Canada, it's Kirkland Brand (Costco)- always best price.
Do you mean, your local privately owned Kia store?Mobile One is the choice of KIA
Not according to my manual. It states Total QuartzMobile One is the choice of KIA, but are the other opinions out there about motor oils that are better for the Stinger? One example is Royal Purple.
Any opinions or experience with other synthetics other that Mobile One? I hear AMSOIL is pretty good.
Putting 5w30 in the 2.5? Or wait til warranty is over?I used to buy that years ago when Costco first started carrying them and were even cheaper. Now they are around $18/5qt, which is still very good price, but occasionally some of the name brands go on sale on Amazon for about the same price, so I tend to stock up when that happens. I do wish Costco would carry more than just 5w30 and 0w20 though.
I stand corrected. I suppose that many of these synthetics are fine as others have posted on this thread asNot according to my manual. It states Total Quartz
Those are for other vehicles I have/had.Putting 5w30 in the 2.5? Or wait til warranty is over?
I've been using mobil 1 0w30 from walmart, $25-28 depending on time of year for the 5 qt jug. Takes 1 1/3 jugs with oil filter here.
I'm simply saying that an engine with 5w30 (or 5w40 for that matter) in my neck of the woods wouldn't see a "low temp" kinematic viscosity that is any higher that what you would likely see in yours.We get temp swings from -20F to 100F, so I guess I'll be sticking with the mobil 0w-30. So far my mileage has been under 5K, sometimes well under 5K between OCI's, do it at least once a year.
At 4800 miles the oil didn't look too bad, dark honey. By product of turbo engine. The G oil changes were done at roughly similar mileages, but looked much better.
Can you rephrase "At say, 20degC, 5w30 likely has a thinner viscosity and flow better than 0w30 at -20egC"? You're comparing 2 very different temperatures. ¿?
The one your using doesn't meet the ACEA A5/B5 thats specked in the manual. Or even the ILSAC-GF6AI use Liqui Moly. Felt like it eliminated any slight smoke I had. Car runs great just ticked over 100,000 Miles.
And it's not even correct weightThe one your using doesn't meet the ACEA A5/B5 thats specked in the manual. Or even the ILSAC-GF6A
I believe we're spec'd for A3, and GF-4 (GF-3 at launch). And the API was SL, then SM, because SN was pretty new and SP didn't exist. I did a deep dive on this at one point, maybe I'll post my notes when I get time.And it's not even correct weight
I would just add that a "2-gen newer" oil isn't definitively any better or worse than a "2-gen older" oil at protecting the engine. It simply means it has been tested to the new standard. Sometimes, it could be the same exact formulation. Other times with a slight addtiive package tweak, here and there. Once tested and passed, it gets put in a new bottle and sold with the new label. As you mentioned, sometimes the newer standard specs requirements that has little to do with better protection.If your oil is API SP, you are at least two generations newer than what Kia designed for, and have LSPI protection (specifically for direct-injected turbo engines). ILSAC just adds fuel economy requirements, but it's like a 1% improvement (they use 20w40 as a baseline lol).
Ok fair point...maybe the way I should've phrased it is: whatever the supposed benefits of going to SM or SN over SL, if you go all the way to SP you're getting the anti-LSPI formulation which is relevant for modern turbocharged DI engines (especially torquey ones like ours, which are likely to run closer to "lugging").I would just add that a "2-gen newer" oil isn't definitively any better or worse than a "2-gen older" oil at protecting the engine. It simply means it has been tested to the new standard. Sometimes, it could be the same exact formulation.
If squeezing every last HP out of your engine is the overriding goal, then that is what racing oils are formulated to do. However, do bear in mind for racing teams, long engine life measured in years and tens of thousands of miles isn't a priority. Quite often race engines are overhauled after only a few races, so they can afford to trade a little less kinematic frictional loss for a few more HPs, which might mean the difference between winning 1st place or finishing 2nd.Driven high performing/racing oils are my choice as they have very low evap rates at high temps. I use DI40. Though a bit pricey and not available everywhere (so I order it), I have more confidence in it than Mobil 1 or other oils. Here is a link to it: DI40 5W-40 Synthetic Motor Oil, Quart. I'm sure there are many other great oils and its really personal preference of course.
