Where’s My Boost At?
Buklau
Toronto, Ontario
Mods: MBRP Catback, Ark Secondary Downpipes, AEM Intakes. GT2/Limited 3.3 AWD
Hello! So recently I’ve run into a problem where my car makes no boosts. It happens sometimes when I decide to drive spiritedly.
When I accelerated and it gets into the high RPMs, usually over 4K, the power cuts out as if I let off the gas and I get my usual intake “woosh” sound. After that happens, when I give it a lot of gas, it doesn’t build boost and give me the power and push it usually does. If I turn the car off and back on, it’s back to normal. It builds boosts again and I get the power previously.
I’ve checked some of the hoses and it seems okay, I might have a more in depth look at it when I have it in my condo garage this weekend. Any advice?
Ps. It’s also been very cold recently. Does that affect it at all?
It's over boosting from the cool air mixed with secondary cat delete
Really?? I thought that only happens when you get primary downpipes. I’m a noob to mods if you couldnt tell...
I had mine do it with intakes a catback, j4 map 3 and like 18 degrees f lol. Logs showed 0 boost under load and no check engine lights.
