Hi Everyone,
I've just ordered 2.0T Stinger and I'm staying in Singapore. It's comes with the 18" wheels, non staggered and no brembo. I believe it is 18x8 +45 225/45/18. It is not flushed with the fender. I'm intending to replace with aftermarket 18 or 19" wheels and also upgrade the brakes. I need some advice on what specs of 18" and 19" I can go for to have a flush look and also at the same time give me options to install a big brake kit.
18"
Front 18x8.5 +30? 225/45/18?
Rear 18x9 +30? 255/40/18?
19"
Front 19x8.5 +30? 225/40/19?
Rear 19x9 +30? 255/35/19?
I am hoping someone can advise so that I can start to do wheels shopping in Singapore. Please help.
The major issue is your brake plan. As you probably know most after market wheels will not clear big brake packages such as Brembos because of the caliper thickness. So if you are planning to upgrade the brakes you are going to have to ensure you select a wheel that has been designed by the manufacturer to fit big brake packages. It is the basic wheel design that determines if the wheels will clear big brake fitments (not wheel offset) so don't assume that every wheel with a significantly lower offset than stock is going to clear the brakes you have planned.
If I were you I would stick with the 19 inch plan and 225 40 19 and 255 35 19 tyre sizes KIA uses on some of the stinger models like the 6 cyl GT. If you order a set of the 19 inch wheels KIA uses on the top of the line GT fitted with the brembo brakes you will be getting a wheel that clears the Brembos and offsets that work for tyre clearance on body and suspension. You can have them painted any colour you want if you don't want to keep the stock colour. When updating the brakes just use the same brembo brake package KIA uses with the 19 inch wheels and you won't have any issues to worry about.
If you want to go aftermarket wheels fine but when you get the car check how much space you have to play with on the outside on the rear where you are using a wider tyre. Using a lower offset wheel than the stock wheel used on the GT with the 255 rear tyre will push the 255 tyre out further and closer to the edge of the rear guard. How much depends on the offset you go with.
