oddball
- Sep 19, 2018
No one can say for sure besides topping it off if you notice it’s low. It all depends on how much you drive, your outside climate and what you do while driving to find out.How often does everyone top off their coolant?
I topped off last September. And I had to again recently. I get white smoke at cold start but I thought it was just condensation.
some good points. Both times I topped off there was still some coolant at bottom of visible reservoir. No milky residue.Bear in mind this is the expansion reservoir. Even if the coolant level drop to the bottom when cold, the cooling system will still function normally.
Even if you need to top off occasionally, the amount is tiny compared to the overall coolant volume in circulation.
As long as there are no other signs of abnormality, like milky engine oil, there is no real concern.
Yes, if there is something else worse that is causing consumption of coolant, the car will show other signs to let you know about it. The white "smoke" on cold starts is just water vapor that condenses into tiny droplets in the still-too-cold exhaust. If that was really coolant leaking through blown head gasket, your coolant level will likely drop way faster. Plus some of that coolant that get sucked into the combustion chamber will make it into the oil sump and turn the oil milky.some good points. Both times I topped off there was still some coolant at bottom of visible reservoir. No milky residue.
Up until the point when the reservoir runs dry and radiator starts sucking air in.Bear in mind this is the expansion reservoir. Even if the coolant level drop to the bottom when cold, the cooling system will still function normally.
Mine was at the low mark at the 600 mile 1st oil change; topped it to about midway up the dipstick scale.How often does everyone top off their coolant?
Of course. The point was that the expansion tank is there to allow the coolant room to expand/contract. Just because the coolant level is at the "MIN" mark doesn't mean the coolant is "very low" and a cause for grave concern. It just means it's time to top it off a bit.Up until the point when the reservoir runs dry and radiator starts sucking air in.
2FWIW, those L/F marks on the stem are kinda goofy. Every time I've pulled the cap, I could not tell what level it's on that stem. Besides, the translucent tank kinda makes the marks on the stem rather pointless.
Yeah, I'm not 100% certain either. Just some educated guesses from looking at it. I am quite sure that it isn't a simple OVERFLOW type reservoir. It is possible that this reservoir is one of the two remaining types:
1. EXPANSION type that sees radiator pressure, or...
2. RECOVERY type that can return coolant only after the system has cooled down and is no longer pressurized.
Probably No.2 is more likely. Either way, the reservoir level will ebb and tide with the overall coolant volume in the coolant system. That I'm quite certain.
