If I make a right turn under hard acceleration the transmission remains in low gear at high rpms even after letting off the gas, and won't go into a higher gear even if I manually upshift or "pop" the pedal. Eventually, after what seems an eternity, it will upshift and go into normal rpm. It only does this on right turns. Left turns are completely normal. What is going on here?!
