Tail light alignment
That adjusts the whole hatch position. I popped out the taillight access covers on the inside and loosened both screws so that the entire assembly was loose. There's not a lot of play in it, but I was able to push it while tightening it to change its position. I did also adjust the hatch position via those rubber stops, but that was minimal alignment of the actual hatch and quarter panel.
Thanks. Might try that too. Adjusting the rubber stops to even the taillights ended up that the left side hatch is a tiny bit higher than the body panel now (on a left side, because it was lifted all together), while the right side “hatch/body” ratio is OK. So may try your way to fine tune it.
My alignment was thrown off by using 1/16” neoprene rubber padding in the hatch to stop occasional creaks. Not a peep now, but a slight misalignment you have to look really close to notice.
