Tobstertx3
Texas Stinger Swarm
Hi,
I've had my car for 2 months now. Since then the temperature in Houston has been almost 100F every day, so no need to use my sunroof. The other day, the temperature was a little cooler in the morning so i thought i'd open the sunroof. The sunroof works fine when you pull the button back - the sun shade slides all the way back and then the sunroof opens and slides all the way back.
My understanding is (and also checking the owners manual) that if you push the button forward, the sun shade should slide all the way back and then the sunroof should tilt all the way back.
Is my understanding correct? When i push the button forward, nothing happens?
If so, anyone else experience this issue? I did see some instructions for resetting the sunroof but little concerned on trying this as there is a warning that it may not work properly if done incorrectly.
Thanks!
Thanks!
