WildBill
The spare is the main central support for the deck. If you were going to remove the spare then that's where I'd put the box and sub.
Sounds like a good plan on the mounting location.
I was thinking that tuning that monster in with all the links in the chain would be fun.
That Epicenter with built in LOC sounds really good product right about now huh
You'll get it, it might just take a bit of time.
Thanks.
Correct on the box placement. Doubled up for added strength and to give me a little bit more space. Some pics of the finished box below.
View attachment 8914 View attachment 8915 View attachment 8916 View attachment 8917 View attachment 8918
Took the passenger side panel off as well and tapped into the front speakers. Surprised the front speakers still work they way I was pulling on some of those wires to splice them in![]()
Can you send those pics you have of the driver and passenger sideMade some progress and have the box pretty much done. Just need to throw some black carpet on it and put in sub and speaker terminal. Going with the JL 10TW1-4 which only needs .35 cu ft of space and this box comes in at around .375 cu ft plus I will be adding some poly-fill.
View attachment 8843 View attachment 8844
While I was waiting for some wood filler to dry I decided to start taking some trunk panels out and I must say it was a little more involved then I thought. Unfortunately I did a dumb thing and removed the driver side panel as I thought the image in the first post was of that side but was of passenger side. Should have looked at it again before I took it off as the fuse panel is on the passenger side. SO if anyone needs pics of what is on the Driver side of the trunk I have them.
