K8 Stinger Store
Authorized Vendor
Thank you for your order with us!
Before
After
This ones a little better, I need to take a pic with the sun facing the car. I think its taking me longer to take a proper pic than actually put the springs on![]()
It's been dropping more, I can no longer pull over the curbs at work with my front bumper. I took the initial measurements in my Mom's garage so I wont take final ones until after the alignment next Monday and until I am @ her place next.
I did a black/white photo because I think it separates the shadows better, they were blending into the top of the tires making it hard to distinguish a difference.
Following with interestI can also get that measurement for ya once it settles a bit more, and once I have access to my Mom's garage which is nice and flat.
Final Measurements:
Front Stock- 27 9/16 inches Front Lowered- 26 10/16 inches
Rear Stock 27 1/4 inches ( I posted this wrong, think I put 27 1/2 inch) Rear Lowered - 26 3/4 inches
So looks like the front has dropped just under an inch, the rear is probably pretty close to the .6 inches advertised. So you will get more than the .8 advertised on the front with AWD, but barely. Hoping the rear drops a bit more; I may get a second alignment near the end of the year just in case since it seems that these did drop more than my initial drop measurements.
Really enjoying the ride when it's not vibrating (cv axle issue) pretty comparable to stock in comfort mode on long cruises, but on sport in the city is more rough than stock. I can definitely feel the stock sway bars being inadequate now, there's a lot less body roll under lower speed turns but the back end still feels quite squirly under certain conditions (higher speed bends, really pushing the car around corners).
Front Lip Lowered - Just under 7 inches @Gtecko
I've gone down a few very steep driveways and I cleared; which lip are you installing??installing my lip this weekend and I will measure my clearance but that seems a bit low for the snow/curb lol
That would be great. Thanks.I can't verify at the moment, but I can try to get one in that same spot later today.
