Stinger 2.0 Premium - California
The front badge looks crooked ? or is it the way its shot that makes it look that way ??? :sick::sick:
You were right about the front badge being crooked. It’s fixed now but it wasn’t as easy as I thought. I’m not sure if the badge tabs or the holes in the bumper were not in the same exact location but I had to modify the badge tabs a bit to make sure it’s straight. As most of you guys know now, the US spec front bumper has thee holes but the third hole is on the opposite side compare to the Korean version which requires to cut off the third hole badge (lower) tab. Well, it seems there might be more to it because even if I wanted there was no way to install the Korean badge perfectly straight in the US bumper without (slightly) modifying it.
I finally received my Stinger emblem for the back of the car and had the time to install it. Look great!
After removing the small OE STINGER emblem (from the left side) and playing a bit with it, I figured it looks cool on my license plate frame.
Actually I would buy a license plate frame with an embossed Stinger sign (and not taped like I did just for fun). I do think though that the font would be better if it was a bit smaller than the OE emblem. Thoughts?
The new Stinger badge looks great! Somehow the smaller Stinger badge looks less redundant on the license plate as opposed to on the left. I guess it just sticks out much less...
I see you're a mad man like me and must cleanly remove your license plate characters the way I do. :p
That's what Photoshop is for isn't it? :D
