Pnbnationsbest
@MisterMac you know who drives slow on 696, HEMI DRIVERS! They get angry when their boats are made to look like anchors.
Drive slower.
Seriously, you shouldn't be running into oversteer situations if you're just driving normally, unless normally for you is driving 8/10ths in the rain. My tires don't break free on the way to work.
Could you please explain what this means?So, last night, I used chalk (lengthy process or trial and error) to identify the ideal psi.
So you were able to adjust oversteer/understeer balance with tire pressure adjustments?
Inverse guy. The tie was overinflated so there was less tread on the ground.So reducing psi in front increases oversteer?
SMH. I meant to write understeer. I saw understeer in what I wrote and "now" it says oversteer. This thread has seriously messed with me.Inverse guy. The tie was overinflated so there was less tread on the ground.
Video on tire chalkingCould you please explain what this means?
I'm sorry but I'm with Merlin on this. An over inflated tire that has less contact patch in my mind would allow the front end to push more, which is understeer. I have no doubt that changing pressures has solved Mac's problems, but it may be a bit more complicated where camber, caster, contact patch, and sidewall flex all have some part to play.Inverse guy. The tie was overinflated so there was less tread on the ground.
I'm so sorry!Edit: guess it is playing with my head as well Merlin
I'm so sorry!My edit isn't helping. But it makes me feel better.
