Corleone1
- Aug 14, 2020
1-3-5 cyl bank misfire
I was cruising with very low throttle input for 30min's before it happened.
It happened as i started to accelerate from the lights with maybe more than 50% powaahh lol
We had about the same now with a client Stinger. We first tried other fuel with 30% E85 but the same. We did check plugs, Nippon, and they where bad really with to much gap, 2 centrum electrodes were off. We changed to HKS 45 and all good again.
It also have happened that the knocksystem puts down timing so much that you go to zero timing that also will cause missfire like symtoms. What I have seen it has been "sound" from lose shields that make knocksystem to think engine is knocking.
So... check your plugs and see of some around engine is loose. It has never, in my knowledge been a broken knock sensor as the dont break.
