itguy61
Correct. I looked at it today and I can see the jack points and there is a small opening right there I presume to put a lift or jack in. I am hoping it is side enough to get jacked up with either a floor jack or the jack in the trunk and then set the jack stand right beside it and gently lower it onto the jack stand for stability while I change out pads. I did not see anywhere under the car to put the jack stand without removing the cover under the power train area.
