PRESSERtech Kia Stinger GT Dyno RESULTS!!
Discussion in 'The Ultimate Kia Stinger Tuning Forum' started by PRESSERtech LLC, Jul 11, 2018.
  1. PRESSERtech LLC
    PRESSERtech LLC United States Member
    68
    104
    33
    Wow Jonathan. That is a tough one for sure. You are obviously a man of great character. I'm sure we could all learn something from you. Good luck sir.
    • Like Like x 2
  2. Never thought
    Never thought United States Stinger Enthusiast
    934
    356
    68
    Arizona
    So maybe I missed it but are your numbers from the crank or wheels? How would someone who lives out of state do this?
    • Like Like x 1
  3. PRESSERtech LLC
    68
    104
    33
    We code within the same software version so the chances of them knowing you have a tune at the service level are low but certainly not impossible. If it is ever overwritten by the dealer, will will reflash the ECU for free. You just pay for shipping. The same goes if you ever want to put the car back to stock. We will keep your original tune and the performance tune on file for 5 years from the time of purchase. This is not just something we say because we're new on this forum, it goes for every tune regardless of car brand. Cheers.
    • Like Like x 4
  4. PRESSERtech LLC
    68
    104
    33
    Both sets of numbers are on the report at the top of the thread but the process is simple. You remove your ECU, ship it to us. We will tune it and turn it around within 24 hours (weekdays) and send it back. It's very simple.
  5. Never thought
    934
    356
    68
    Arizona
    Ok so 393 at the wheels (50 or so HP increase) and what looks like power loss under 4500 RPM? Am I reading the dyno right?
    • Like Like x 1
  6. SteveCo
    SteveCo Canada Stinger Enthusiast
    691
    241
    Calgary, AB
    The graph is a single dyno result, with a line each for HP and torque. Torque gradually falls off as HP climbs, so the lines cross around the 4500 mark. Make sure you read the correct values for each curve (on each side of the graph).
    • Like Like x 1
  7. Never thought
    934
    356
    68
    Arizona
    Thank you!!!
    • Like Like x 1
  8. SteveCo
    691
    241
    Calgary, AB
    Also, the 365 HP number published by Kia is at the crank. Once you add the approximate powertrain losses back into the graphed result of 393 WHP, the apparent HP gain is much more, closer to 100 HP than 50 - assuming the stock setup would have matched Kia's published number on that dyno.
  9. Never thought
    934
    356
    68
    Arizona
    It’s hard to say and see how the power curve is compared to stock without a dyno run on the same car without the tune.
    • Agree Agree x 1
  10. Dochidalgo
    Dochidalgo Mexico Active Member
    PRESSERtech....will you sell a spare ECU with your tunning???
    • Agree Agree x 1
  11. KLR STINGER
    KLR STINGER Canada Active Member
    296
    221
    Was this AWD or RWD?
    • Like Like x 2
  12. PRESSERtech LLC
    68
    104
    33
    Absolutely, we are trying to find a good source for stock computers. In the meantime, you are welcome to source one yourself and send us both computers. We will leave your orig stock and flash the new computer with your cars immobilizer data and program data, ghen tune it!
    • Like Like x 1
  13. PRESSERtech LLC
    68
    104
    33
    This was a RWD Stinger
    • Like Like x 1
  14. Schumi Jr
    Schumi Jr United States Member Sustaining Member
    75
    24
    Cincinnati
    Stock plugs? No regap?
    • Like Like x 1
  15. PRESSERtech LLC
    68
    104
    33
    No sir! We have developed this with no adjustments needed to plugs. We have 1000 miles on our tune and counting with no issues
    • Like Like x 1
  16. Schumi Jr
    75
    24
    Cincinnati
    Wow. Good for you guys.
    • Like Like x 1
  17. robz32
    robz32 United States 1000 Posts Club! Staff Member Moderator Texas Stinger Swarm
    1,520
    698
    Houston, TX
    Very impressive guys. Keep up the great work.
    • Like Like x 2
  18. junesrig
    junesrig United States Active Member Sustaining Member
    114
    38
    Northern California
    Any issues with CEL?
  19. PRESSERtech LLC
    68
    104
    33
    No, we have put 1k miles on car. When we calibrate the software with our tune we keep adjust the parameters to turn on cel. Basically, the cel will come on just like it would if there was a problem in factory flash. From what i have read the cel probs seem to occur with piggyback modules. This is an ECU calibration.
    • Like Like x 1
    • Informative Informative x 1
  20. junesrig
    114
    38
    Northern California
    Thank you, just wanted to know, would not want the check engine light driving me crazy.
    • Like Like x 1
Draft saved Draft deleted
Share This Page
