Plugs replaced + intake upgraded + jb4 installed! 2018 stinger gt
4oz to a full take of 93 pump gas, they actually sell 4oz shot bottles but they are way overpriced but I bought them anyway and will refill them since they are super convenient.
Why do you prefer E85? I had huge problems with it. My car didn't like it at all. 5gal of E85 to a full tank of 93 and I started getting CEL for low octane so when back to only 93 and it went away and have been using Boostane now with no problems.
I've never had a CEL. Low Octane? Don't understand that.
Boostane will wear out your plugs faster. I would check them no more than every 10000miles. E85 is easier to get. E30 runs cooler. E30 is less expensive for octane improvement. Corn.
Yea I can't explain it but that's exactly what happened put in 5gal of E85 and filled the rest up with 93 in an empty tank (light was on) mixed it up good and the next day CEL for low octane and didn't go away till I used up all the gas and put in a fresh tank of 93.
1. Boostane will wear out your plugs faster. - Yes, I've read that
2. E85 is easier to get. - Maybe for you but not for me, I have to drive out of my way to go get it. No gas stations around me or on my daily drives have it.
3. E30 runs cooler. - True
4. E30 is less expensive for octane improvement. Corn. - Nope
E85 down here in FL is $1.50 to $2.00 a gallon, you need 5 gallons so that's $7.50 to $10
Boostane for 2 16oz cans is $40 shipped free from Amazon and you need 4oz so that's $5.03 per 4oz shot.
Duh, how much is Premium Gas? You are replacing Premium gas with E85, not adding an additional expense to the tank of Premium you have. So if E85 was $1.50 and Premium is $2.25, you would save $3.75 a tank with 5 gallons of e85. So with your example, you would save almost $9 a tank to use E85 vice Boostane.
Like I said, I've run both for over 30,000 miles and I prefer E85. The only advantage I see with Boostane is I can have it when I need it, if an area does not E85, and that's how I used it.
LOL Duh your right forgot about subtracting 5gal of 93
