RonNSoCal
I just had my oil changed at a local independent shop and noticed the oil left in my second 5 Qt jug seems to have over three quarts left in it. I provided a filter and the oil and expected more oil would be needed since the manual says 7.3 quarts are needed to fill, whereas only about 6.5 quarts was actually used. I checked the dip-stick and it is up to the top, and the oil appears very clean. Is this normal? Does the engine hold close to a quart of oil that does not drain out during an oil change?
