TurboEncabulator
I've got a '19 Stinger GT1 AWD - K&N intakes, JB4 w/ Fuel & EWG wires. I've got access to 93 & Unleaded 100 (by 5gal pale). I've tried map 3 & map 5 with a ~95 octane mix but it will drop to map 0.
The log attached is a heavy pull getting on the highway with the new EWG wires - Just after 100 it dropped to map 0 and put the car into limp/no boost.
I did just change the plugs as the first set of denso's had 20k on them & the gaps weren't all even.
This run:
Pid was set to 15 and FF to 55 w/ Shell 93.
I've been playing around with different Pid/FF combinations to see if i can iron out the map drop under heavy boost but I think I'm beyond what I can figure out at this point.
Thanks for any help you can give!
This run:
