Yes I have been meaning to post a tutorial on this so I will get a small one going here.
The things you need to do this DIY Catch can are here
Amazon Shopping List - (corner brace not included)
1 - Catch can (I used a large Mishmoto clone)
1- 1/2" hose
1 - 3/8" ID 5/8" OD hose
1 - Roll PTFE Yellow Tape
1 - 16mm Oil drain plug
1 - 5" steel corner brace (pictured) - I purchased this at my local Ace Hardware
1 - Nylon nut (pictured)
Mishimoto clone
16mm oil drain plug put on the bottom of the catch can
Barb with Yellow PTFE to seal the can better. Keeps the smelly gas out of the compartment.
Yellow PTFE tape
5" steel corner brace to hold catch catch can
3/8" ID 5/8" OD Hose
Mishomoto 1/2" Catch Can hose
You're going to drill and shape the brace to eventually hold the catch can. This is where the brace attaches to the car.
When you're done shaping your brace should look something like this. Test fit as you shape the brace. The 2 small holes are where the catch can attach to the brace.
You're going to purchase a 1/2" Nylon washer for the can to "sit on" (shown in the next picture)
You'll cut a 30 degree angle off the corner of the nylon washer. The side of the catch can will rest on this nylon.
Your catch can brace will look sexy when you paint it. Right?!
Next step is to take the large "foam hose" and pull it off the old hosing.
Measure 14.5" of 1/2" hose. Also note the approx. length of the foam hose and it's position.
Both hose sizes 1/2" on top 3/8" on bottom.
The 3/8" hose is approx 11".
Catch can installed with 1/2" hose side
Catch can final install.
In retrospect, after running this setup for 8-9months now. I probably should have opted for the smaller catch can. There is stuff being caught but but it's really not alot. A smaller can would have worked probably better. My thing was I didn't want to have to mess with it a lot and the current price for this mod (when I was looking months ago) was ridiculous.
I hope these instructions help someone.
