Map 7 log check
rbf351
After some installation issues I finally have my WMI up and running. Can you please check my log
thanks in advance
Feedback given on another forum
Those on this forum that come to learn and aren’t on another forum won’t. Please no offence meant.
Good point, Below was my comment and the link to the post. My thing was he posted the same log in two locations on two forums at the same time. I hope you understand that I can't reply on both all the time.
It's not bad but plug 4 is pulling a bit more than the rest.. 3 deg. Not too concerning but it's super easy to get to and pull out. Check that gap. I'm not sure what they are now but I recommend .022-.026
If you posted the plug type and fuel you were using earlier I'm sorry I missed it. Can you post that?
For now stick with 60 until you verify the condition of that plug. Then I think we can go higher, you're hitting 20 psi now which is good.
