Brian B
Im experimenting with the idea of using user adjustable map 6 to help me out over a mile above sea level to help drop my 60' times. The goal here is to see if by using map 6 and setting the boost higher at lower rmps i could launch harder with the AWD GT.
Im trying this to see if it produces a lower 60' then 2.13 results i get maps 1 and map 5. Remember Altitude is the power robbing factor im dealing with not traction issues.
Any suggestions for what to set the boost levels at ? Im running map 5 so i figured I start with 6 psi over stock.
Should I use flat boost across the entire rpm range or do a bell curve for boost like below ?
