I've changed mine on both. But I believe press ignition twice without brake pedal is the proper way. All you need to do is make sure on the laptop set to the right port and press connect in the menu. Once done then can change maps. Default is 0 I believeOk - when I connect my laptop using the correct port, do I make sure the ignition is on or just the aux power?
Ah ok. Car must be on. I gave up with the laptop and just connected the phone via USB-C to USb adapter. Then used JB4 mobile and checked the wired option.
My First map. I got a few good throttle pulls but not wot. Damn jersey traffic even at 9 o clock. The afr looks to lean down on higher throttle. Must be working?
I am almost fighting a bit of torque steer now off the line, but not enough to lose control over it. Bottom line is that the JB4 feels more tailored for the Stinger making it a overall more pleasurable driving experience.
Awesome! Thank you! Saturday I am getting my plugs replaced for around 155 bucks (I have the plugs). Then I will map out #2.
Gotcha, torque steer is what happens to FWD cars when acceleration causes the car to "pull" in one direction. If you had torque steer on a RWD car, there's a serious problem somewhere! The tail kicking out is normalMeaning the acceleration as such at launch the tires break a little loose in the rear, but it catches quickly in front. It's a good feeling. I didn't use launch control though.
And fun.Gotcha, torque steer is what happens to FWD cars when acceleration causes the car to "pull" in one direction. If you had torque steer on a RWD car, there's a serious problem somewhere! The tail kicking out is normal![]()
lol NJWhere are you located? I will swap the plugs for you for $50 bucks. I will charge you $40 if you bring 2 happy meals for my 2 girls.
Fuel wiresGuys! Trying to install my Jb4 just want to ask where the 2 black wires go? Instructions doesn't say anything. Thanks
They said it's already preinstalled.
They are on the jb4. Still need to tap on the car side.They said it's already preinstalled.
Ok so I am looking at my logs and my "fuelen" is all "0"s even under boost. Is my firmware not up to date? Firmware version : 21/7//5
I guess I will have to recheck the wires. Pretty sure I have them both connected to the red wires on both sensors correctly.
@Terry@BMS
Awesome! ThanksThey are on the jb4. Still need to tap on the car side.
