How long did this power loss last? What did you do to recover? Did you have to shut it off and back on again?
The first time, several minutes, as it caught me by surprise and I was trying to figure out what was going on. I kept pressing the gas with nothing happening (and traffic building up behind me) so I pulled off the highway and found a parking lot to drive around in. Every time I tried to give it gas it would just cut power around 2k revs (at one point it it threw a couple of lights, check engine and one more that I missed), so I just parked up, turned the engine off and on again. It was fine after that, although I was very easy on the gas.
The second time today was much shorter, if no less alarming. Same thing, tried to give it gas from a stop, it cut power around
4k 2.5k revs, (and the F-150 behind me almost rear ended me), so I pulled into the shoulder with hazards on, and tried to actually figure it out. It only responded to the gas pedal up to around 2.5k revs, and right when it was supposed to shift up, it would just cut power, and the pedal would be not quite dead, but also not responsive. So, it wouldn't accelerate, but I could also see the needle moving, albeit very slowly/sluggishly. This time, I "fixed" it by turning cruise control back on and letting it get up to speed by itself.
While that worked, I noticed that it barely ever got past 2k revs, going from 50km/h to 80ishkm/hr. Once it hit the 90s and 100s, it would go above that, and once it hit 110km/hr it stayed around 1800/1900 revs.
That's more or less how I got to my destination. Both times I was in comfort mode. On the way back I gave it some juice but I was way too concerned with it dropping out on me again so I just always got up to around 60km/hr and let cruise control take it up to 105.
The first time, yesterday, I did briefly switch it to manual mode and tried to shift myself (because the power loss seemed/felt like it was up shifting to the wrong/higher gear), but that didn't do anything. Also while I filled up yesterday, I'm now down to half tank, although I
have been doing a lot of driving over the two days. And I bought premium, have been using premium for about 2 years (started with regular).
I'm gonna ask the dealership to check the fuel pump, brake vacuum pressure, and
spark plugs.
Edited to correct some numbers, it wasn't reaching anywhere near 4K. On the drive to work today I kept an eye on the tachometer, the car shifts around 2100 revs, and I stay in comfort mode the overwhelming majority of the time. As I pick up speed it maybe gets up to 3k revs or just over, and then it shifts.
